I have been working on a 611b and finally have the motor working perfectly. The case o matic lever has always been hard to move in the 20 years we have had it and I didn't know how it was supposed to work so I don't know if it ever worked. Lever now moves freely and all linkage is hooked up. New filter and fresh tch. Com mode works fine. If I put it in direct drive pushing clutch does not return lever to com. Engaging the lever does not lock up the converter. Any thoughts? I plan to attemept some pressure readings but the convertor tap ,if I have the right one is right under the steering shaft and I will need to remove that. Any ideas what I should be looking for?
