Fuel Strainer for C S Tractors
I am looking for the parts list, and mainly part numbers, for the Case gasoline fuel filters that used the Zenith strainers with the screw on glass bowls. I understand the screw on bowl filters were originally used on the C, S, SC, and SO gasoline tractors. Any help would be greatly appreciated.
Charlie
I've looked on eBay and aftermarket places because I have several tops but the glass bowls have broken. Need three or four bowls but no luck and been looking for several years
would that be the same as on MM tractors, also had two of them on Oliver 535 combines. An old glass Alkeselcer bottle will fit
R Aiken,
MM did use the same filter on the R, Z, and some 403 power plants.We now produce the bottles and gaskets for the filters, and now can supply them reasonably. Right now I am working on producing the valve assembly, hold clip, and the filter element. My records do not mention the Oliver equipment using the Zenith fuel filters, but I will keep digging.
From what I can see; the only difference in the assemblies is the filter element size. The element length was increased to allow more flow. Fortunately all apparently used the same thread, so they are interchangeable.
Charlie
