1494 upper radiator hose
I have a 1494 that I need a upper radiator hose for. No one seems to be able to get me one. The part number is K207335. Is there anyone that can help me? If so let me know. Thanks in advance. Ron
Will this one fit? It says it fits the 1494:
http://www.ebay.com/itm/K201747-New-David-Brown-Tractor-Radiator-Hose-Top-1490-1494-/321540627723?epid=1829991169&hash=item4add509d0b:g:wf4AAOSwg6pZbgiK
Perhaps it has been superseded?
Does the original hose have different IDs on one end than the other?
David Brown Radiator Hose Top 1490 1494
Hello, can't offer anymore help on the hose but I got a 1490, maybe we can keep in touch? My email should be open.
(quoted from post at 17:22:18 08/11/17) Will this one fit? It says it fits the 1494:
the tractors with ac are different than those with out I have ac
Which companies you have tried already? Coleman Equipment lists a k207335 on on their website for $20.50
http://www.colemanequip.com/parts/CaseParts/K207335/
Other than that, I came up empty handed.
I would try to hobo patch using two generic flexible radiator hoses of different internal diameters, cut to desired length, connected to one another with a metal or plastic reducer and hose clamps. You may have to use a rigid elbow on that 90 degree turn. Not ideal, but you may be out of options.
K207335 at Coleman Equipment
