Radiator Removal On A Case 530 CK
KCTractors
Location
Central Wi
Hey John Saeli, I found the holes to loosen the radiator bolts on the bottom of the radiator, but how do I get the radiator out and back in with that lower radiator the way it is? I'll probably change the fan belt to and that looks like a job too. I thought that I had a repair manual for this machine, but can't locate it now that I need it. You have any suggestions?
I don't have any suggestions, but what do you mean when you say "the way the lower rad. is? It should simple slide forwards, as the holes in the tractor are slotted, last I remember.
