New neighbour acquired a 2294 with the farm he bought but has issues that are puzzling
# 1 it has no grunt when you depress the pedal and both switches under the dash were checked and are good
#2 it will grunt if you put it in reverse and then you can put it in gear
we have found a couple issues one being a bad coil on a power shift solenoid and replaced the circuit board with one we knew was good. What we need is for it to grunt when its supposed to not in reverse.
Suggestions????
Suggestions????
