430 Power steering?
dkeav
Was power steering an option on the 430 diesel wide fronts? Mine is arm strong, and might have to try sourcing the parts to make it power.
I received the seals to repack the power steering rams for my 430 today, so yeah they came with power steering.
But, +1 for it being too much fuss to make an armstrong model powered, but that's just me.
Maybe look for a junk 430 with power steering and rob what you need off it?
I believe the very early smaller 30 series (630 and down) tractors came with the Charlynn steering column mounted power steering system.
(Also VERY hard to come by) but the conversion is easy as there are no cylinders to mount on the front axle. I converted my 630 this way. If
you have a JI Case parts list and Case factory service manuals it should show this mechanism.
Jim
(quoted from post at 07:37:18 08/03/17) I believe the very early smaller 30 series (630 and down) tractors came with the Charlynn steering column mounted power steering system.
Jim
My 611B has it. Doesn't do much, but my steering box needs rebuilt, and I haven't even gotten around to checking the pump pressure to it. I saw the unti listed for 8 or 900 bucks new, still available, forget where. Add the price of a pump and plumbing, and the time/trouble of fabbing brackets. If you want I'll look in my manuals, it might have instructions for mounting it on a 430, it does for the 500s and 600s. Let me know.
I mean if you have the time and ability, then even if I wind up not using them, posting them won't hurt anything for someone else looking for that information. The more info we can get "archived" onto the internet on these old things the better, before its lost forever.
AFAIK it's all still available, the info I mean, I think the manuals are out there. This one is pretty clearly wrong for your tractor, it doesn't cover the 430, closest is a 411b. But just to get a general idea what might be involved, here you go:
Looks somewhat daunting, I assume the brackets and all came in a kit back when, you'd have to do a lot of fabrication. Might also be worth your while to try to find another steering shaft to slice up so if this project doesn't work out you still have a tractor. Good luck and let me know if I can be of any other help, not that I think this is going to be much of that, but you know...
Wow, those aren't very clear either, very hard to read. Well, if you need the text, holler and I'll jump through some hoops and upload a .zip to MediaFire and post a link. But I don't want to do that for nothing, so please only ask if there's need.
The usual Char-Lynn torque generator used in these old tractors was Eaton p/n 217-1015. First pic I wrote in the specs. They are obsolete but some replacement units are nearly identical. They are popular with the off road people and are readily available. They seem to run around $600 new but I don't recommend buying used as on your tractor it will be mount output shaft end down and any debris present in the unit will end under and destroy the output shaft seal. I have 2 of them with that seal blown. There are seal kits available but is just complicated enough to give the average guy fits, including me and I resealed dozens of them in the 70"s.
Char-Lynn with a gear driven hyd pump was usually used on the GP tractors. Utility models usually had a belt driven hyd pump with a front axle mounted hydraulic cylinder due to heavier front end, loader, some w/diesel. The Char-Lynn applies torque via the steering box while with the axle mounted hyd cylinder the only steering box torque is that required to move the hyd cyl control valve. The 2nd pic is the steering lever with studs. If you are going to use a Char-Lynn, especially with a heavy front, diesel, loader etc, you need to have those studs in very good shape and set to proper backlash between the studs and cam (worm gear). Worn studs/excessive backlash under stress can break the steering lever.
The rest of the pics is the installation procedure on the 00B tractors. I am only familiar with the 1960-1964 ag and utility 430 and it is the same or nearly so. Note that you need a side rail to mount the unit bracket. The side rail is an easy fabrication, the unit bracket not so much.
Go to the link and view the 2 different types of PS on the early 430.
Joe
http://partstore.caseih.com/us/parts search.html epc::mr56605ag4822456
Shoot Kevin next time I'll check before I go to all that time waster. I posted all this once before but somehow lost it. I started on the scanning before dinner.
Joe
Well Joe at least you have the correct tractor here. What I have is earlier, mine is a '59. And as I said, the PS isn't worth much.
See this is why I love the internet. That is a crazy amount of useful information right there. Thank you gentlemen for taking the time to share your resources and knowledge it is appreciated.
(quoted from post at 10:41:31 08/05/17) See this is why I love the internet. That is a crazy amount of useful information right there. Thank you gentlemen for taking the time to share your resources and knowledge it is appreciated.
Just pay it forward, maybe it'll start looking like the human race is worth saving after all.
(reply to post at 13
i have a case j.i 430 g 1962 tractor i need the parts catalog for it can anyone one here help ,s/n 8199450....there was a person that had one .its been 2 month an he sill not got back ..is the anyone that has the parts catalog that i can buy a copy of.i have a tractor that i can not get the righy seals for they have told me with out the right numbers it is hard to mach the right get to the power steering cylinder.
:23:58 08/05/17)
an i have also called called case an they told me that they was not able to help.so please if there is someone the can help .it wood be greatly appreciated
Have you checked right here on this site? Right at the top of the page I'm writing in now is a button that says "Tractor Manuals".
