SC restoration pics
Finally done with the 53' SC
That is a very nice restoration, great job, makes me want to get to work on my 49 wide front and 53 narrow front.
Thanks for posting
Ben
The late SC foot clutch tractors had 16" front wheels and DC steering column/ steering gears. Nick
You have done, a superb restoration of your "SC3" as others have also said. You have to be so proud, as you should be. I'm glad you are part of this forum
Dan
Is that where the tool box is mounted ? I have a tool box but it's mounted to the side of my right foot . Also my box is black with the red letters .,,,,,,I have a 48 D3. Your tractor looks great !
We had a new farmall 706 with painted alternator. It didn't last long, had it rebuilt, that didn't last long either. Got a new one not painted and it lasted as long as we had tractor. Someone said paint restricted heat dissipation. Don't know for sure. Pretty tractor.
Wonderful tractor. I have a carb question that maybe someone on here can answer. Is that the right one for an SC? I have one like that that came on a 1952 SC that I bought and when I started working on the tractor to get it running the inlet on the carb was larger than the outlet on the air cleaner. I can't figure how to make an air-tight seal between the two. Do the newer air cleaners have a larger outlet than the early ones? Thanks for letting me use your post to ask my long-winded question. Dale
Is where you placed the tool box where it is supposed to go ? -..what does it connect too ? ,,,,on my 1948 the tool box sets to the right of my right foot...also my box is black with red letters .. ...-- obviously ,you did a great job . Congratulations . :)
Is there a bracket that comes out from the block ? Is it obvious ? Bolts or brackets ? ,,,,,, anyway thanks ,,,,,, Your hard work is a pleasure to see . 👍🏻
