Case Knob Handle
Determined
Need some of the black knobs that screw on to the throttle, gear shift, hydraulic control levers on a Case 1070.
Tried looking on E-bay and either I do not know what to call them or nobody is selling them.
Anybody have a source for them or should I just go see the Case dealer.
bought some almost like it at our local Baumgarrs store, think you need 1/2 course thread for that these were like the early ones and are round
cnt
I've a later 1070, and the lever is slotted and the rubber knobs just push and lock on. You simply pull up to remove them. I tried our local dealer last fall, he said they were available but were on order all winter so they must be NLA now days.
yes that is true in 1976 they dropped the srew on knobs and went to the rubber ones, the lever does not have threads with the push on style
cnt
This one was in my 970 when I bought it. I believe it is probably an old bar tap. I like it as it is a little bit longer on
the throttle and the gold looks good in the black knight .
A big thank you going out to Jean Claude Marleau.
A set of knobs arrived yesterday.
Now I can grind gears in comfort.
