Wanted: oil seal for CASE SC starter
Greenfrog
Autolite starter # MZ4095
Center plate with oil seal
Is a small oil seal about 1" in diameter
Keeps engine oil from housing from getting into starter motor
This seal fits into a recessed place in the center plate.
Is 1942 case sc
Will probably need one for a CASE DC. Have not determined that yet.
Also....the cork gasket that goes around the DC snout of the starter that fits up against the engine housing, would like to replace that..
Have you tried taking the seal to an auto parts store?
I have two Sc's. The seal is shot in both. One Sc I've had for 29 years the other on 26 years. Ive only had to clean the oil out twice in both. It takes a long time before you get enough oil in the starter to cause a problem.
Thx for the encouragement here.
Nothing much done here either...
The sc the field coil is wrapped in cloth and the oil over time deteriorated it and allowed the wire to touch th armature and ground out
Repair place seems to think that the little oil seal is vital.
cnt
