Bro and I had a Coke ,,
Case Nutty 1660
Wife stopped and grabbed us a burger on the way home, this was the cup I got,, I also spent the day tearing into a swather to keep my 1970 955 running as the header drive belts are NLA and I hate to scrap out a great running machine but the 1150 has two of the belts and should keep the 955 running for many years I hope
cnt
Hi Tom, I see those machines have variable speed set up, how do they get reverse? Can't see it they have the plant. system that some used. Do they have the slant 6? Rod.
Napa sells those double sided belts and they are not even that spendy. And they work great as replacements for the round belts case uses some places. I put one on the header drive on my 955 to replace the round one that was on there.
Rod, the header drive belt also is the reverse drive as well as the belt turns the reverse of the rest of the drive, these both have the Case 159 gas engines in them, the baby Chrysler slant-six was in the 1075 machines, they also use the 225 version in the 1275 the last two models produced for Case
cnt
Interesting as I have been searching for a year to find anyone who sells them Jay-Dee does not,, I will have to get with you , do you happen to have the part# still? Call you soon Jon thanks
cnt
Case nutty can you explain something about the belts you need like the width or length.
For some reason i am thinking I have saw those belts somewhere. If i can have a little more info i might be able to find the source again.
