I started my 1370 and heard a noise so I shut it off and realized the starter was running even after I shut the tractor off.
The key switch was turned to the off position and the starter drive was not engaged but the starter motor was still running.
I was able to disconnect a battery cable but the starter will start running again by reconnecting the battery cable. This si
with the switch in the off position. I pulled the starter to check the drive and i can not find anything wrong. I checked the
solenoid with an ohm meter and I can not find anything wrong. i checked the wire coming from the start switch and I can not
find a problem.
Some how the starter wants to keep running but not engage the starters drive. I've tried to check everything I can think of
with no luck.
Any suggestions?
The starter is an MT35 Delco Starter
find a problem.
with no luck.
Any suggestions?
