J&R Farms GA
New User
I have acquired a 1935 model C and I need some information from you Case guys, ( first Case for me).
1- I need the diameter and height of the intake tube that comes through the hood.
2- Where can I find the part of the air intake that bolts to the exhaust manifold? Or can some one give the dimensions of it and I'll make one.
3- Is there an oil filter? If so, where is it located? ( I have a operators manual and a parts manual, but its very vague on this. or I am just over looking.)
4- When I picked the tractor up the radiator was full of antifreeze. While diagnosing why I lost spark and cranking the engine over the water pump started leaking. Is there a seal kit I can purchase? Or just replace the water pump? If the later, Where can I find one?
I have been searching the web for info on this tractor. Should have just come here first cause I know I will get the correct information.
Thank you in advance for the help, I'm sure there will be more to come.
Thank you,
John @ J&R Farms
Thank you,
John @ J&R Farms
