Hi there,
I have a 65 Case 830 Comfort King, row crop it is not a Case-O-Matic. The bearing on the front of the pinion shaft went out and trashed the pinion and broke some teeth on the ring gear. I got on Ebay and bought a brand new in the box ring and pinion, when I got it home the pinion has 10 teeth instead of 9. Both ring gears have 49 teeth. I was wondering if anyone has put the 10 instead of the 9 and what it did to the tractors speeds. The shaft is the same in every way other than the amount of teeth. What would be the different application between the two shaft? Thanks! Nick
