Matthewanderegg
New User
Hi, I have a DB 990 running on 3 cylinders. Ran fine last summer, family went to start it over the winter and the oil bath (for air cleaner) was full of water. It ran until I presume they revved it and sucked up water. I have cleaned the fuel system, replaced filters and had infectors rebuilt. Timing is good, pressure to injector on dead cylinder seems good. Aside from a compression test not sure where to go from here. I ran it ok 3 cylinders for about 3hrs in hopes it would clear up with no luck. Can't imagine the compression is so bad it wouldn't fire. Any ideas are appreciated, need it running asap to cut hay.
