in need of 630 PTO
gusbratz
I bought a 630 case-o-matic dual range tractor with the 188 diesel recently. somebody took all the pto stuff off I am assuming to rebuild it and it has been lost.I appear to be missing the clutch plates, actuating lever and output shaft. I was wondering if anybody had a parts tractor or maybe knew a good tractor junkyard. thanks, gus
i have a lot of trouble with posting pics to this site. i have to put it in classic view and attach them one at a time. image codes don't work here and i don't know why.
I have some of those units complete from 600B tractors,will check n see if they are the same, $250.00 if it will work.Im in northwest Wisconsin
(quoted from post at 13:09:43 06/18/17) I have some of those units complete from 600B tractors,will check n see if they are the same, $250.00 if it will work.Im in northwest Wisconsin
i would appreciate that, i had trouble getting into the case parts site. i have a 530 parts machine here i thought of trying to use. but it looks different. you can contact me at (my user name)@yahoo.com
thanks for the help guys. parts are on the way from jean claude marleau. will try to post a pic when the machine is back together.
the parts arrived today and i got them assembled and installed. The direction of the keyways on the clutch fork was a bit of a puzzle but i got it done. Strange how the clutch fork just sort of floats back and forth on the shaft with no set screw keeping the keys in. hopefully they dont fall out and get eaten by the gears. I still have to adjust the clutch.
Right now i am wondering what goes on the shifting rail on the upper right hand corner of the pto assembly. I see that it is for disconecting the PTO coupling. I assume you would push it in to unhook it when operating the tractor for extended perods of time when the pto is not required? Was there a knob or lever or something on it originally to pull it in and out?
