2394 hydraulic and powershift issues
ssjurson
New User
When using our 2394 Case, the PTO lever disengaged by itself but kept running. I also lost power steering and power shift at the same time. Any ideas on what's wrong?
need more info,when you say pto kicked out but kept running?not uncommon for pto lever to kick out when press.drops,like when you push in clutch.i assume hyd.press.did not return?steering and power shift are 2 different pumps if both die I would think about pump drive gears or limiter clutch,maybe oil supply?
