Chris in SK
I?ve got a 1070 with a bad PS trans. (I brought it this way just for the tires which I?ve swapped onto another tractor). The 451 motor is in pretty good shape. It?s an older tractor and I?m not really interested in attempting to fix the PS unless I split it and find something obvious and cheap to fix. I might consider switching the motor/front half onto something. I?ve seen a 2090 and an 1175 for sale with blown motors. Would either of these be an easy swap? 70 series go pretty cheap around here now, so I don?t want to put too much time or money in. With the 1175, could I split both tractors at the bell housings and roll the two good halves together? (I?ve split a few Fords, but never split a Case). I know the 1175 is turbo and 8sp. Any other interesting candidates I should look out for, to swap the 1070 motor into?
Thanks,
Thanks,
