Does Christopher Mikesell still make pivot pins? Contact?
DennisT
I understand a certain Christopher Mikesell did, or does, make pins and bushings for the Case SC WF nose pivot. If so, anyone know contact information????
My '53 SC WF has egg-balled hole in the center of the front axle and my machinist and I are trying to figure out how to repair it. He can bore hole out to true with his milling machine, but what material was used for the bushings? He can bore it, steel sleeve that hole, "then," put a proper bushing in.
And I also hear there is a 4-degree slant to the front end to provide, .. is it caster?, to be correct. Need to understand this also.
The Christopher I was referred to apparently makes, or did make, some of what we need.
Dennis
