1370 pto clutch
brentb
I have been having some issues with my pto clutch slipping on my 1370. Yesterday it happened again and I had a hard time getting the pto to turn off. I have a few more acres to cut. Can I finish up or do I need to get the clutch rebuilt now? Also how big of a job is it? Any ideas what parts will cost me. Thanks. Brent
sounds like you have slipped it enough it has warped backing plates, not a bad job to do and can be done in a couple hrs at most,, I recommend rebuilding if you have a lot to do as you can warp them bad enough it will not shut off at all,, when you do rebuild it replace the piston seals and all clutch disc's and backing plates and shaft seals, worse part of the job to me is draining and refilling the 30 gallons of hyd oil,,,just my two cents
cnt
