Onlymenotu
New User
First of all I"d like to say HI all. I read and searched the archives many times on different projects like ford 8n,Luc,Ac D17,JD A"s and last but not least our MF 2244 bulldozer. The latest project is a Case 530 (ck)? The serial plate on the tractor says it"s a Case Mod. D530B serial# 8217566. The guy I bought it from says it is a 1959 model! This link, http://www.ytmag.com/cgi-bin/snlookup.cgi?mf=CASE&md=430,+530,+530B,+630,+730,+830,+930,+and+1030, says a 1963 model.
It"s a Loader/Tractor/Backhoe combo, seems like it’s a factory setup. He gave me a manual with it that is only some what useful at best. Seems the info is for a 530 backhoe/ tractor (just not my year) a lot of the info in the manual is totally different which leads me to my first question what would be a good shop manual for the tractor? The backhoe/ loader manual seems pretty accurate.
The tractor has not run in 4 or more years, I was told the last time he used the tractor it ran fine, when he went back 2 days later it would never start and run again. He said he tried once to give it a shot of ether, and it would run and die. He gave up on it, and it has sat ever since. This is where I enter the picture. I had done a little pre-buying research, and found it had a Rossamaster IP on it. So I searched the forums and found all the typical problems i.e. stuck metering valve, bad plastic ring, plugged check valve, stuck plungers ect. ect.
This brings me to my next questions. My Rossamaster DBG431-27AJ pump has no check valve on it, and from doing some research of the IH-Case parts for sale online, doesn"t ever appeared to have one? It just says ELBOW, is that right? Or has someone already drilled it out? If it never had one should I put one in when I reseal/repair the pump to help it to hold pressure and stop the hammering effect & fuel drain back that can be caused without it? It had the usual problems: stuck metering valve,* which I freed up* & no pressure to the injectors...so the plungers must be stuck.
John could you give me the current part#"s bushing, reseal kit, the updated ring, the transfer pump blades, check valve (if needed on this model of pump), the little clear plastic timing window, and whatever else you think I may need when I call Usdiesel * I"D AT LEAST LIKE TO PRETEND I KNOW WHAT I"M DOING WHEN I CALL THEM..roflmao*
To-JDEMARIS could you please email me here Onlymenotu@gmail[dot]com I"d like to discuss some of your other off topic projects…( I went through your 726 pg photobucket pg).
