Bohemian32
I could use some guidance, my D has a lot of loose play in the steering gear. I see there is an adjustment screw and lock nut. From the picture in the parts book, I am not sure just what tighten that screw will do.
Part number 07174AB1 Described as Screw, Adjusting, Steering drip arm shaft.
Is anyone familiar with this adjustment. or most likely all the parts will be so worn that no amount of screwing will cure my free travel.
Any thoughts on this.
