BE MANUAL A702
chuck machinist
I had a fellow YT member find a BER 3-14 mounted Plow last week, and I may have jumped the gun on a BE Manual. Are they quite similar,or are they worlds apart as far as part numbers. Thanks for the barn find Ben. CM
The BER is the mounted Eagle Hitch plow, while BE is a trailer plow. I know moldboards etc share the same part numbers but that would be about it. I've got a BER manual and parts book for the 2/3 bottom SC/DC plow. Also Service Bulletin #46, dated July 14th 1955, has instructions for using this plow on the real 400
Nice plow! Should work good behind the 400. I thought BE was Eagle Hitch plow and BER was Eagle Hitch Release plow for the break away rock trip. Got a 2/16 BER with the older style release.
Thanks for the responses . Ill keep my eye open the BER manual then. I suppose if I hang on to the BE manual, one of those will follow me home . HEY! CM
Good looking plow Chuck! I have a twin to it. They pull pretty easy when scoured and adjusted correctly.
Eli
