220 and the Haban Mower
1370rod
After some adjustments and learning the do's and don'ts of operating this little outfit I find operating it to almost be fun. In a couple hours I cut a ton of brome grass
and weeds. I will be doing some baling in a few days. Rod.
After seeing you bought this, it went on my wish list with all the little ones I have! Great post Rod, always good to see you
Dan this worked so well I did not use my T-10 mower this year. The only negative I have seen is ground clearance, the mower mounts low under the tractor and I have gotten hug up on really ruff ground, but I soon learn to avoid it if I could. Rod.
Looks great. I have, what I think is a Haban. Missing the knife.
Came with a 446. Need it ? Southern Michigan.
