Eagle Beagle
If I am correct, a 41 SC did not have a bypass oil filter as original from factory. Years ago, I scrapped an AC cartridge type filter that was mounted to the right side of the battery support, in an attempt to " look original ". Even thou a low flow filter would not seem to help much, I would like to replace it on the tractor. If I remember, it was blue and white. If anybody knows where one is available, with brackets, please let me know.
Also, early SC's had a rubber rebound cushion for the seat suspension. This was above the channel that supported the seat and the 5/8th's bolt that retained the coil springs ran thru it. I have tried to replicate one, but rubber products I am finding are to hard. Original was gum rubber and quite soft. Any idea's?
Pic of rebound cushion.
