kevinthefixer
Recently bought a Case 611B, rough shape but still runs, and it came complete with manuals. Now, the wiring diagram clearly indicates a positive ground system, but I found the battery connected negative ground. Yet the tractor still starts and runs and charges the battery. I can understand the old mechanical regulator getting its polarity reset on first use, and setting the polarity on the generator was a routine procedure back when we had generators. But every starter motor I've ever seen the inside of (at least hundreds if not thousands) was a permanent-magnet type motor. The remote solenoid doesn't care about polarity, so of course it's going to send power to the starter--but why does the starter not spin backwards and the bendix drive hold the pinion gear away from the ring gear? AFAIK only motors with field windings (either series or shunt-type) will spin the same direction if the polarity is reversed, and then only if it's reversed for both armature and field windings. Did Case use a field-wound starter motor? Or was there a version of the 611B produced with negative ground that's not mentioned in either the owner's or service manuals? They really didn't have to work that hard to confuse me, it just sort of comes natural, as Huck Finn said. Anyway, since it ain't broke, I don't plan to fix it unless someone has a very good reason to; there are plenty of things that do need fixing on it, including some major fabrication on the loader cross-brace. But this is bugging what's left of my brain (I did a LOT of drinking in the folly of my youth), and I'd appreciate any insight anyone might have. Thanks!
