My Dad just gave me his 1977 580ck extendahoe, under the condition that I fix it, and he gets to borrow/use it (smart man). I have already had to replace the ring and pinion in the transaxle a couple years ago.
Now, it has no forward/reverse for a while warming up. He said he reved it up for a while, and then it made a horrible "bang" and began to move, and then reverse nothing and then "bang" and began to move. The shuttle is not working correctly.
I have the manual, but it only lists Main pressure @ idle 65 psi neutral, and 130 psi @2000 rpm neutral. There are no listings in the manual for forward and reverse pressures @2000rpm, just a worksheet to write the numbers down. I bought a transmission pressure gauge 600psi to do some diagnostics on the main and converter output ports.
What pressures should I read for forward and reverse @2000rpm?
