my triple range 530 has been leaking hyd fluid from the triple range box into the rearend for a couple years now. i finally pulled the covers off this week and found that there are bits of seal and metal all over the inside of the rearend. i can see that one of them is a double lip seal but what was the big piece? is there like a carrier pressed into the bridge wall between the trans and rearend that the seal pressed into? when i look at the shaft it looks like the pressed metal seal outer part with no garter spring or rubber in it and i can see the bearing from the rear of the tranny main shaft up in there. so can i just pull the pto and press a new seal in there or am i missing something? any help from those who have seen this not broken would be appreciated.
thanks, gus.
thanks, gus.
