Vai gear ratios
So I have a 49 vac row crop that I tractor pull it has 38 inch rear rubber and in 2nd gear it runs way to fast for our mile per hour class. I have found an industrial less than 30 miles from my house that I can buy cheap my question is,"would the vai have a slower ratio in the rear end or transmission?" Thanks and all help is greatly appreciated
Not likely as it should have 24" rubber, which will slow it down. Neighbour's vai has a different shift pattern vs dad's vac13, maybe there's a difference in the trans gearing.
Then I'm to slow I pull 8 miles per hour and first puts to much torque but not enough speed second puts my torque right at the rear wheels but is to fast I'm at 10 miles per hour in second and 6 in first going down the track
