Case SC PTO Fork
Roger46
Are all the PTO shifter fork detent slides broken? Mine is broken at the first detent as the slide is very thin there. I went to the salvage yard and had the mechanic take one off the SC they had in the bone yard and it was broken in the same place. It works OK even if broken as you can tighten the nut and hold it together, but it sure looks like a bad design.
