So my 930 diesel wasn't charging. Put new bearings and brushes in the generator and it didn't charge. Took the generator to a shop to have it tested and the regulator was bad so it was replaced. Put it back on the tractor and it still won't charge. I did figure out that the light on the dash was also burned out. I have been testing for charging with a clamp on amp meter and not by the light on the dash. Does the light on the dash have to work for it to charge? All wiring has been verified to be intact and correct. My other thought is that maybe it is not spinning fast enough to make it charge. I know that there is a smaller aftermarket pulley available.
Thanks,
Eli
Thanks,
Eli
