Hi Guys
I finally replaced the rockshaft seals on my 530(541L) tractor. I neglected to take photos of the position of the arms when I took it apart. I am thinking that the rockshaft needs to be all the way down but what position should the arms be in? Right now I have them 1/4 turned down from being level on top but it does not seem correct. Should the flat part of the arm be horizontal on top? I don't see anything in the manual about this.
Thanks
Pat
PS..John S the seal kit with the plastic seal and oring worked fine. I had to heat up the plastic seal with a blow dryer and muscle it in place. I then let the piston set in boiling water with my ring compressor on it and tightened it up while hot. Let it cool and the plastic seal went right back in place to original size.
Thanks
Pat
