Diesel flywheel
460anger
Putting a diesel engine in a 530 that was gas the diesel engine is out of a Case a matic tractor can I use the 530 flywheel?? or will I need to find a diesel one thanks in advance
The experience I had with an 830 case was the diesel starter drive had 12 teeth and the gas drive has 9 teeth but they should be the same otherwise. If changing from a COM to a standard clutch set-up the fly-wheel of course is different and must be changed.
