970 hydraulics. Solved
deere37
After changing pump takeing. Flow divider apart. With. No change. Shifted. Fine and steered. Just No 3pth Or Remote pressure. Took. Remote valve off and found couple o. Rings. Shot. Thanks. To. All those That Responded with Possible cures. The knowledge Here is phenomenal.and. priceless
Good to see you found your problem. I enjoy reading replies on what folks figured out on their malfunctions. Too often a question is asked, good advice given, then you hear nothing back. I'm about to tear in to one of those on the same model. Spools are stuck. Its on the bench waiting for a rainy day...I think it has arrived.
Thanks
