case4994 transmission controller
Does anyone know where I can get a transmission-steering electronic controller that mounts in the cab behind the hydraulic remotes on a case 4994. It also has wiring running to the crab steering control and the switch that locks the rear steering straight or in turning mode. I have had one repaired but they do not seem to get it fixed so I need a different one. Thank You
Gary, Sounds like you have more than one brain box. Do you know who the original MFG. was? Sometimes you can get some extra help from them. Tom
A while back a guy on Agtalk posted about those controllers and his solution:
https://talk.newagtalk.com/forums/thread-view.asp?tid=145043&posts=15&highlight=Case%204994&highlightmode=1#M5023100
