So I use one of the VACs I have a lot but it is a real pain to get on. It has the Stockton 3 point hitch on it so the bars etc are in the way to get on form the front side. And from the back if you have sometime on the 3 point again it is hold to climb up on. Plus with my bad knee that does not help or my bad back.
Also the 3 point does not seem to lift as much as it should. I have tried to shim up the relief valve but that did not help. Been thinking about swapping out the whole PTO/Hyd unit since I have 2 extra ones
