Not all that familiar with Case tractors, but the brakes act like automotive brakes. With the pedal depressed there is a good short flow of oil then is slows to nothing, shouldn't there be a nice solid flow as along as the pedal is depressed? Either side is the same. Hooked up a flow meter to check pump flow, had 6.25 gpm free flow, spec 7.0 and at 1750 psi it had 5.75, should have 6.5, steering is not as easy to turn as I think it should be, but the lower spindle thrust washers are gone and spindles are cocked in there for now, need to jack up the tractor and see how it steers with no weight on the wheels. thanks chris
