Posted other day about. Loosing. Hyd. On. 970... still. Puzzeled . Its. A. Later model. Took. Lines. Loose. At. Pump. Before. I. Pulled. It. To. See. If. I. Had. Oil . Started up. And. About. 30 seconds. Squirted. Oil . Put. Lines. Back. On and. All. Worked . For. A while . Shut. Tractoe. Done. And. When start. Ba k. Up. No. Hydraulics. If. I. Crack. The. Small. Line. And. About. A. Min. Or so. I. Get. Oil. But. Not. Enough. Pressure. To. Raise. A case. 4. Bottom. Plow. Or. A. 12. Foot. Disc. Pressure. On. Dash gauge. For. Ps. Is. Up. In. Green. When. Its. Pumping. Think. The. Pump. Can poop. The. Bed. That. Quick. ... everything. Was. Working. Fine. Friday. Till i shut. It down. To. Fuel. .
