Case VAC. I have it running but still needs some TLC
old
So I put in a new set of points and it starts right up but after running a few minutes it starts back firing out of the carb. I do not have any coolant in it as of yet so it does heat up pretty fast. I figure I need to pull the valve cover off and set the valves. Only problem is with doing that is I do not have a manual for it so not sure what the intake and exhaust need to be set at.
Any body know the correct setting for them?
Thanks
Thanks guess I'll have to see if I can get the valve cover off with out hurting the gasket to much and set them
