1170 throttle cable....
casecollectorsc
Location
E central SD.
Well, after 47 years the throttle cable gave up on the 1170. Anybody got a good way to get the nuts loose on the cable end under the floor board? Should have the engineer here. Guess the floor needed a good wash out after that long anyway. Next is to see if Case-IH has the cable.
Steve, I'm going to the farm tomorrow, if you have the part# I can check if I have a OEM
It will be over 100 bucks from your friendly dealer. Check around and see if there is a local shop that makes cables, price will be around 60 bucks instead.
