Case VAC carb questions 8N carb
old
So I finally got around to checking to see if a carb off an 8N will work on a VAC and it will not. The VAC uses a wider carb stud set up then the 8N carb has. Plus the air cleaner hook up is opposite of the VAC. So I will see if I can build a good carb from the VAC and 8N carb
