Last fall while ripping my tractor would act like it ran out of fuel , changed filters ,, nothing , then added a small electric inline pump hoping that would help and it did seem to help for a 100 or so acres , but then it got worse it would start great then after 10 minutes it would die or almost die and after a few seconds would run for a short time and then die, it kept getting worse till it would hardly run more than a few seconds when you started to pull something , this winter I bought a little overhaul kit Case has for hem that consisted of a couple springs and plastic plungers and gaskets , thought that might help and really no way to test till now , well it didn't help , it might start right up and even idle just fine as soon as you put a load on maybe 10 seconds or so it dies again , could it still be fuel pump ? if I open the line to the injector pump there seems to be a lot of pressure there even after its shut off , thanks for any input
