Case570lxt
New User
Hi there I have a case 1996 570lxt. And in not 100% sure if I am running the rear auxiliary hydraulics remote properly.
I downloaded the parts manual..but it shows very little about controls and operating.
It looks like there is a actuator where the filter is mounted.
But I don't if it something that has a switch on the dash.
I don't know if it is a series two or one.
Apparently there is a diff lock. And the switch is located besides the 4x4 switch. But I'm not sure. Because there is a peddle between the gas and break peddle. I thought it was the clutch. But didn't seem to work. Ivery only had the machine since early fall.....and it seems like I have a little bit more learning then I thought. I'd like to get a operating manual...but in the meantime any help would be greatly appreciated
Thanks in advance
Thanks in advance
