Case 570lxt operation hydraulic rear auxiliary
Case570lxt
New User
Hi there I have a case 1996 570lxt. And in not 100% sure if I am running the rear auxiliary hydraulics remote properly.
I downloaded the parts manual..but it shows very little about controls and operating.
It looks like there is a actuator where the filter is mounted.
But I don't if it something that has a switch on the dash.
I don't know if it is a series two or one.
Apparently there is a diff lock. And the switch is located besides the 4x4 switch. But I'm not sure. Because there is a peddle between the gas and break peddle. I thought it was the clutch. But didn't seem to work. Ivery only had the machine since early fall.....and it seems like I have a little bit more learning then I thought. I'd like to get a operating manual...but in the meantime any help would be greatly appreciated
Thanks in advance
I have not been in one but if you can post some pics I may be able to help you more, also check behind the seat back the backhoes have the ops in there maybe yours is still there
cnt
(quoted from post at 06:06:35 03/28/17) I have not been in one but if you can post some pics I may be able to help you more, also check behind the seat back the backhoes have the ops in there maybe yours is still there
cnt
The spot besides the 4x4 switch is a blank. I'll assume I have a series one...the pedal looks like it is the difference lock....darn..I just went through the winter not knowing it was there...
Anyway I'm more interested in the hydraulics... I just looked and yes there's a wire going to that spot....I'll have to put a test light on it. And have someone flip switches....but might not even be connected. Or might not be what I'm talking.
Could just be a sensor....
I'll post photos in a while...
