My Case 465 Prototype.
Adirondack case guy
Well at least that is the model number that I gave it years back. I really need to get it done before I die, cause no one else will ever figure out how all the mechanical linkages work.
A 30gpm front mtd. pump supplies power for hydrostatic power steering, and the loader with boom hyd. remotes. The tractors hyd. pump supplies the eagle hitch plus a rear remote.
The cab is a pod design with rubber mounts from 90 series DB cabs. All the clutch and brake pedals are overhead mtd. including a foot pedal that operates the hand clutch on the triple range. It has two clutch pedals side by side on LH side. It also is a 2 door cab with RH control console for 3pt and remotes, and a built in joy stick for the loader. at the front of it.
The tank at the rear is for gas, and the hyd. tanks is a custom fabrication that is nested in where the fuel tank and bat used to be.
The hydrostatic steering system is off a 660 combine, and the T&T steering column is from a 90 series Case tractor and the brackets are all fabed. There is a console that covers it and has all the gauges in it along with the heater console that you see laying on the seat.
I haven't formed any of the hood panels yet and have a bit more to do on the fenders. The chassis I have already painted DB brown. The cab and hood panels will be desert sunset, loader and wheels power red and black paint on the horizontal rails with graphics like a 70 series plus some more details on the fenders and top of cab.
Loren
Loren,
With all your amazing talent and skill, that will be an awesome tractor. I enjoy all of your fabrication talent sir. You would put many mechanical engineers to shame. Thank you for all your amazing pics in the past. I look forward to the future pics as well.
Kow Farmer Kurt
If anybody can get it done , it would be you and your magic hands ... looks like you got things going just have to do the small stuff ....
........... mark
Jim, It is just a 1963 440 with a 148. Triple Range with eagle hitch, 14.9 24 rears and currently on 7.50x16 fronts. Thanks for all the complements; just doing what I think Case tractors of the era could have been.
Loren
