New year project/ Eagle Hitch up and running!
CZ
Well, this is close to the closure of a 2 1/2 year project. This weekend I got the pump mounted on the old girl and did the last of the tubing runs. Checked all the fittings one last time, filled her with hydraulic fluid, bleed the system. Then with fingers crossed I started her up, no geysers of fluid, no horrendous noises, she just stood there and ran like normal, controls worked, even in the right direction! Now I need to get my test pressure gauge on the system and set the pressure relief valve.
I for one would like to see more pics of your wooden Case tool box.
Would you consider making one for me? Email is open. Thanks.
I made the tool box several years ago out of white oak, the logo is hand carved. My tractor was missing the original steel box and rather then replacing it with one of the reproductions I decided to do something a little different.
I think it is just stunning with the Case logo on there. Yes, keep me in mind if you would make another. Thanks.
