Wreckmaster
I have just bought my first Case and bought it as, "Has to warm up." (EBAY) Well I haven't gotten it to warm up yet cause it won't stay running long enough. It cranks up then goes dead repeatedly. If you leave the gas on, all of the gas leaks out of the air intake side of the carb. It looks like its been rebuilt so I took it off and took it apart to check the float and needle valve. I removed float and checked for leaks and made sure it was level, so I bent it down a little to close the needle valve sooner to see if that would help and put it all back together and it didn't make any difference. I don't know if they all do but this one has an up draft carb. Does anyone have any idea what this might be? Thanks,,, Mark
