So a few weeks ago a guy came in looming for a bushing on the foot throttle for a 530. No longer available. I am in the middle of restoring my 530 myself, so I was thinking great now what am I going to run into? Upon taking mine apart it was corroded badly but was able to make it out. Its actually a thin piece of steel piping that has a slit cut In it to just provide just enough spacing for the pedal bracket. Normal bushings are way too large. It had to be something very thin wall. I walked around Menards for over an hour and found these sandblating nozzles. Perfect size! Took a hacksaw and cut the slit. Just have to grind the sides to fit and will be better than new. Should be same for 630. Figured I'd let you guys know if you are restoring one.
