KCTractors
- Location
- Central Wi
On a earlier post about how to use the Torque Converter on a 1967 530 CK tractor back-hoe, just realized that maybe, I don't have a torque Converter transmission. I really didn't run the unit much only to warm it up to change motor oil and fuel filters.If it had the torque converter, wouldn't the lever be on the right-side of the dash panel? There is a lever that comes out the right-side of the transmission opposite of the shuttle lever. I never played with that lever on the right side. I have no control lever on the dash, just the throttle on the left. I am thinking that lever on the right is a high-low trans. Would I have maybe the 8 speed trans with out a Torque converter? Tomorrow, if it's warm enough, I'm going to fire the unit up and see what that lever does and try to get some pictures of it. Thanks again!
