Case 2290/MFWD
dkinni1
New User
Has anyone ever when through all the work to change over a 90 series 2wd tractor to a MFWD.I can locate most all the parts for this change over,the front axle,driveline,bell housing and drop box.However some say you have to change the ring gear and pinion.Why, is it a different ratio? If anyone has did this before,would be great if they can tell me more about it.Thank-you
The front of the Pinion shaft is longer on the front and has a spline that a coupler goes on to drive the input into the drop box. I am sure you pinion shaft will not have that. Chad
