188 wrist pins needed
mEl
Location
NC PA.
Hey guys, I am looking for a set wrist pins for a Case 188 Diesel used, must be in good condition with no appreciable wear. Have an engine project that requires a pin size change going on. The pin size is 1 1/4"
Any help or leads will be appreciated.
Thanks, Mel
Sorry mEL, I suffered brain fade. The IH pins are 1.125 diameter. I did have a set of 188 pins from a Case forklift overhaul, will see if I still have them.
The DC pin is located by a groove in the pin that allows a bolt for a clamp style. The pins could be used if they have a thick enough wall to not compromise the strength of the pin by grooving it to allow a portion of a 7/16 capscrew to pass through.
I dropped you a email expanding a bit on what I am doing.
When is a good time to call when the pins are in your hand so we could talk about that angle? I know the 188 pins being Diesel have a very thick wall and would be ideal as a groove would not compromise the strength to any great degree.
